Would a exhaust leak cause hi-nox?
That1Guy
Car: 240SX s13 Fastback
I fail smog a couple days ago because my timing was off and I had hi-nox level. So I just the timing and it was retarded little too must and thought if it was retarded that much nox should be low. So I did a seafoam on the vacuum and I notice that smoke was come out near the header area close to the down pipe at. Is it possible for a leak before the cat to cause hi nox? I'm thinking the egr not circulating right.
s13k1d
Car: 1991 240sx
iirc nox is only caused by high combustion temps.
That1Guy
But EGR help to low nox level. I know that already.
s13k1d
Car: 1991 240sx
yes. that could be your problem. how bad did it fail by?
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
My car failed the last emission test four times in a row with incredibly high NOx. Turns out the injectors were clogged... car ran fine though. I had them professionally cleaned (pressure) and it passed flawlessly.
s13k1d
Car: 1991 240sx
asoomal wrote:My car failed the last emission test four times in a row with incredibly high NOx. Turns out the injectors were clogged... car ran fine though. I had them professionally cleaned (pressure) and it passed flawlessly.
thatll do it to. causes the motor to run lean. in turn higher combustion temps.
That1Guy
Think it was 550 max and it measure 860. just need to know if a leak before the cat would be the cause.
s13k1d
Car: 1991 240sx
no if anything the leak will cause really high o2 levels.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
yes it can, but i doubt thats your problem
CRyan
Car: 1997 Nissan 240SX
mmmm. How I love living in a state that isn't worried about the ozone. LOL
vancouverbc
Car: 1991 240sx
no. check the rubber hose that carries exhaust to bpt. it tends to rot.
240sx-egr-tutorial-t427162.html
94_240sx
Car: 94_240SX
Had high nox on mine too. Replaced a cat and passed with no problem. I'm just throwing another option.
Wc240
97 Nissan 200SX
06 Scion xB
vancouverbc wrote:no. check the rubber hose that carries exhaust to bpt. it tends to rot.
l
true that is the most common failure on these, however thats only goin to fail nox on the 25 part of the test, not the 15.
what were the ppm on the 15 part of the test?
