Would a bad charging system cause driving prob?
black g50
Car: 1994 Q45 Black/Black--235/40/18's avh3100 xplode 12" and amp 160000miles.2001 rodeo 190000miles
Hunting my bucking,surging,lack of power problems once fully warmed.Every thing I can think of has been replaced.Main self check says ok,trans check came back with (d)battery low.Alt replaced around(09),battery in Dec.Searched on here and google,but no mention of alt.Car starts fine,no dim lights,sometimes tach needle jumps at red lights.Any thoughts? One more thing how long does seat heater run with car off?
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
I noticed you didn't mention anything about the MAF sensor.
Have you checked that?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Seat heater does not run with car off. OEM alternator or third party rebuild? Lots of problems with the latter.
Q451990
Definitely sounds like the MAF to me.
That low battery code gets stored in the A/T Check memory for a while... Run it a few times to see if it persists.
Heath
cientortas
Car: 1994 Q45 Blk/Blk
I haven't posted here in a while, but I am experiencing something similar all of a sudden. What is your voltage at the battery at idle and at 2000 rpm? Mine seemed a little low at idle, 13.1v, so I think my alternator might going south...could also be a bad ground.
I'm not sure if this would cause the issues, but worth correcting regardless.
Q451990
13.1V is low at idle. Should be around 14.2-14.4. I would get your alternator and battery tested... if it's just the battery, the extra load on the alternator could take it down with it...
Heath
black g50
Ozzie wrote:I noticed you didn't mention anything about the MAF sensor.
Yes maf changed.
