would a 91 transmission fit a a s14?
f34_s14
Car: 240sx s14
i was told that a 91 transmission would work for a s14 (1995) 240sx because its has the same engine but when i took it to get replace the guy said its two different transmission and that if i put it in ..it'll lose power and the engine light would pop up..please help thanks
93HATCH240
Car: 1993 NISSAN 240SX HATCH
umm i think the guy is b.s you. I have a 95 motor with that years trans and it drives and shifts fine.
soslydwaysjon
yeh that transmission works as long as is a ka24de
bone_stock_240
Car: 1995 Infiniti Q45
You may get a check engine light because the 95 transmission has a crank angle sensor, and there is no sensor on the 91 transmission. The crank angle sensor is not necessary though, so your car will run fine stuff.
r3v_v3ng3
Car: 91 fastback ka-t
thats probably what he meant by different just missing the hole for the crank sensor. you can swap the bellhousing and should be fine if you need the crank sensor
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Works but you need to drill the bellhousing to fir the crank angle sensors. Try the flashing search function.
Klits562
Car: white s13 coupe
my friend had a s14(not sure what year) ka24de in his 90 hatch and he used his single cam trans for it
