Every 245 wide tire I've seen suggests rim width between 8-9.5"... just like thesehttp://cgi.ebay.com/ebaymotors...ZWDVWgucio69 wrote:I'm looking to put 18" rims on my car and the ones I like come only in 18x7.5 with 45mm offset. I was wondering if this is wide enough to mount a 245/40/18 tire on. I spoke with 2 different people at discount tire and oddly enough got 2 different answers. From what I've been able to research though the tire should fit as I see people with 20x7.5 rims running 245 width tires. I'd appreciate it if anyone with more experience in this area could give me an answer.
Thnx, Eric.
just checked, you're right... why do think these other tire companies suggest 8-9.5" wheels for 245 tires?audtatious wrote:The 6th-Gen maxima came stock from the factory with 245-45's on 18x7.5" rims
You bet they'd fit.EzeebMOS3 wrote:I've been looking at NISMO wheels for my car. Most of them are 18" with 8.5 W, and 45mm offset. Would these wheels fit on the Altima coupe 3.5??
i think its a bit of both...the stock tires are just average at best, I never felt surefooted when hitting corners in the stockies. Also, the ride height of the stock suspension setup affects stability also. That's why the lowering springs + wider tires on aftermarket rims (or even factory rims for that matter) make a huge difference in regards to cornering. Obviously, a full suspenion overhaul would be the ultimate answer, but for the average daily driver, I think they would be perfectly happy with the lowered car and wider tires!gucio69 wrote: and I'm not quite sure if it's the stock tires that are to blame or if it's just the way suspension of the car reacts to the road.
It will be very bulgy. But it will mount.D-Roll wrote:245 tires will fit on a 7.5 wide rim
