Would 20x10 fit on 03 sedan??
dynamikimport
Car: 2003 Infiniti G35
I'm trying to get some rims for my 03 sedan. Has anyone tried to put one on yet. I like the big lip. any suggestion? Thanks
adren77
Car: 2004 G35 Laser Red Coupe 6MT
20x10 will fit. Make sure you get the appropriate offset though.
dynamikimport
Thanks for your help. could you give me that offset. thanks
ArEs23x
Car: 2006 G35X
Well I have 20x8.5 and I remember them telling me if I went any bigger my tires would rub, so I would make sure theres no excessive rubbing or anything, what kind of wheels are you planning on getting btw?
G'd up
Car: '04 G35 sedan Premium PKG Sports PKG AERO PKG
ive got 20x8 45 offset all the way around and if you want the tire to sit right with the right offset your gonna have to go less up front. otherwise your tires mite poke out up front. with a 45 offset you can not fit 10 inches up front.
lightsout
Car: 00 Nismo Maxima SE
a 20x10 should fit in the back, but most G owners go with a smaller/narrower rim in the front. you can fit a 20x10 in rear, but I believe nothing larger than a 20x9 in the front, unless you are in the mood to roll your fender lips...but i doubt that.
TopSecretVQ
Car: 03 G35 6MT
for it to be perfect you will go 20x10.5 in back and 20x9.5 in the front comes out flat with the fenders.
I take that back sorry though you has a coupe, I know plenty of people around here that go 20x 9 on the sedans, not sure of the offset though.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
i think +35mm is the offset you'll want to go with on that
