Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Apr 10, 2018 9:16 pm
The wheels should match in as far as bolt pattern, etc. However, if your M35 has 18 inch wheels, you may want to adjust your tire size as follows:
245/45/18 to 245/40/19 to keep vehicle height the same.
I went to 255/40/19 tires when I replaced my factory wheels with OEM 19's from a Q50. Same height off the ground and wider tires. Looks brilliant.
