woud the z32 injectors and z32MAF help?
Robsx_se
Car: 1991 Nissan 240sx se
as the title say i am wondering if it would help give me some more performance on my non turbo ka24de. also i am considering a set of power pulleys when i switch over to Altima electric fans are the pulleys worth the money?
this car will someday be a daily driver.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Wouldn't help one bit. In order to use the extra fuel the injectors would be capable of providing the engine would have to take in more air. Unless you have some NA mods planned to accompany it, neither would be of any use.
neverlift
NO NO NO
you could run them but at a very small gain. Like 2~3 hp. The thing is that your resolution would be awsomesauce,but without big boost it is useless.The injectors would kinda "fix the over rich condition in the closed loop areas but once your out of those your so rich you power will fall off,drastically. IF you do rom tuning you can run them without any of these problems BUT the gains are still minute without boost.
