WOT issues, I swear this car is going to end me.
Robb_
Car: 1996 Nissan 240SX SE
S14, OBDII KA
Auto Trans
No CEL
Here's where it began.
I replaced the cap and rotor a few weeks ago and began to have issues, problem arose with normal driving. Breakup was around 2500-3500 RPM. Wouldn't go past without me taking my foot off of the gas.
So I replaced the cap and rotor with the OEM one and the problems were still there. Turns out, the plug wire boots were pushed up on top of the valve cover. Pushed them down, issue resolved (sort of).
Problem came back two days ago, I took the plug wires out to make sure the plugs were tight, but the plug wires broke at the boots (yes, the new ones). I replaced the wires, tightened the plugs and the problem seemed to have resolved.
Problem came back the following day. I replaced the plugs and everything was fine until the motor warmed up.
When half/three quarter throttle, everything is fine, but when on the highway and I go WOT, the car will not shift. It will climb until it reaches the point where it will break up and not shift. Let off the throttle a bit, it will shift. It will breakup and shift on occasion only.
NO idea what to do. I'm at a loss and need this resolved. I don't know what else to do. Any help is appreciated.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
I would start by checking the tps.
Robb_
Disconnected the lines from the EVAP Purge Solenoid (Something I fixed right before the problem began), problem remains. Disconnected the MAF, and the car idled normally, but when I tried to take it up the road, I got backfiring and hesitation. Undriveable to say the least.
Robb_
Unplugged the TPS, car just dies.
compactfean
daily
Refer to the fsm proper testing on the tps. That tells us nothing.
Robb_
I stopped and pushed down the plug wire boots again, the issue went away. But it seems like once I take the car to WOT a few times, the boots will push out of the valve cover, only slightly and not noticeable to the eye.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
Robb_ wrote:I stopped and pushed down the plug wire boots again, the issue went away. But it seems like once I take the car to WOT a few times, the boots will push out of the valve cover, only slightly and not noticeable to the eye.
remove the plug wire from the plug and pull the wire where it attaches to the plug farther out the boot tube. then put the wire back on the plug until you hear a click (the wire snapping onto the plug) then hold the wire where it comes out the top of the boot and gently pull on the wire while you finish seating the boot to the valve cover.
