Worth Engine Rebuild?????
Muffdriver240
Car: 1991 Nissan 240sx hatch
I got a 91 240 with 156,000 and an automatic transmission, would like to get it started for turbo wat all needs to be done and how much will it cost?
EazyBreazy
eleventy billion dollars. pay pal me and i'll build it for you.....top right on your screen there is a wonderful contraption called a search button....use it please....this topic has been discussed numerous times this week....as for your question, it is too broad to answer....you need horsepower goals, price range, and if you dont wanna rebuild the engine, you need to check the compression. you need fuel managemant/engine management, lots of little things here and there.. you cannot expect the brains on this board to help you if you dont give them any idea of what your looking for.....and by no means am i saying im a brain...im mostly a prowler learning as much as i can...you should try it.
