Worn VLSD Help
nismodrifter661986
Car: S13 240sx sr20det
I bought a used VLSD with 5 bolt axles for my s13 about a year ago. It was off a r32 with with 4.4:1 NISMO Gears. I notice recently that when i do doughnuts, that the right rear tire smokes a lot more and I get extremely irregular wear the right rear too. After searching with no luck, is it possible to replace the worn clutch pack in my diff and where can I find the parts!
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
shim it
AZ89two4Tsx
A VLSD does not have a clutch pack.
Hence the "V" for vicious. It's fluid that locks it.
Just get a real clutch type or man up and weld it.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
you can shim it, and get 1 possibly a lil more life outa it, or 2 completely blow it in one day. welded, or get a REAL diff, this is why viscous sucks, you never know whats gonna happen
s14derrick
Car: 1995 nissan 240sx
this may be stupid but would replacing the fluid help at all? maybe the fluid broke down. ?
also where would i acquire fluid my car came with the stock vlsd and im changing out all my fluids
nismodrifter661986
Very clean 240 btw....
Yeah the problem with welding it is the unpredictability of the thing I mean this car is my daily driver, I take it for vacation trips, I drive it for work. I would rather not randomly spin out on the freeway when its raining, or hear the chassis bind and creek when pulling into a parking spot when I am out getting groceries or picking up my little sister from kindy care. I got the VSLD for practical everyday day drive-ability so with that in mind what are my options. What kinda of "Real Clutch diffs can a find, maybe JDM or the junk yard"
Crazyirish
Car: Nothing noteworthy at the moment...
The stock VLSD is a sealed unit and cannot be serviced. I would look for another one or upgrade to an aftermarket differential. I'm not a fan of welded differentials for a car driven on the street, but whatever floats your boat.
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
AZ89two4Tsx wrote:Hence the "V" for viscous.
There you go.
