Q451990 wrote:Your situation certainly sounds like flooding for some reason or another. I had a similar issue on my first Q45 after replacing the injectors. It would start fine first thing in the morning, or after sitting for 4 or 5 hours, but let it sit for 15 minutes or so and it started rough and spewed a few puffs of black smoke.
Yep, that's about what I seeing. It takes about 15-20 minutes after shutdown for this to become a problem.
Q451990 wrote:After reviewing the service manual for a '94, which is the earliest model I can find online, it looks like your injectors are of a side-feed design - same as my Q. Long story short, the injectors typically don't fail partially open, so your problem is probably a failed lower o-ring. There are two o-rings and the fuel is forced around the sides of the injectors through the rail. If the lower o-ring leaks, it floods into the engine... if the upper one fails, you get a nice gas leak under the hood.
No leaks under the hood AFAIK. That lower o-ring could be the problem. The fuel in the rail heat soaks after shutdown, expands and leaks into the manifold. This takes a little bit of time to happen and a longer time to evaporate so you get a normal start. This problem came on fairly suddenly and a failed o-ring fits that better than a worn injector which would be very gradual.
Are the o-rings a standard size or are they available from Nissan?
Q451990 wrote:The best way to check for this is to pull the rails, but leave them hooked to the fuel lines. Turn the ignition switch on so that the pump primes and pressurizes the rail, and look for the leak. I have no idea how difficult it is to get to them on your truck... if you're lucky you can just replace the o-rings. Be sure to lubricate them and their mating surface in the rail with a smear of motor oil so that they seat properly and don't pinch.
Oh, and you might want to change your oil soon... the fuel that's not flooding your engine on a cold start has seeped past the piston rings into the crank case and into your oil...
I'll try to do this test soon but I want to have the o-rings in hand first. No reason to take it apart twice!
So you're saying the fuel will get into the crankcase? If the injectors leak wouldn't it go into the intake manifold only or is there a path the to crankcase (like through the cylinders and past the rings)?
Q451990 wrote:Good luck and welcome to NICO!
Heath
Thanks Heath. Very helpful reply and I appreciate the research too.........Bill
Modified by cwilliamrose at 10:04 AM 10/9/2009
