Worn break pads light
rover3l
Car: 1998 Q45, 2000Q45 Anniversary, 1965 Rover 3L,
Still have this stupid light on after checking rears which are ok and rechecking the front electrical connections. One day the warning stayed off for a 30 min drive home from work but all kourneys before and after the warning has been on. I can ask the shop to look at it but I am sure it is something simple. Any thoughts, does it need to be re-set in some way
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You can always bypass them..... Take off the connector and connect the 2 wires together... Probably best you dont cut it off on the harness side where it goes to the car... that way you can use it if you like... If you can find some old brake pads with the sensor/connector, you can use that so you dont ruin..
I might recommend unplugging the battery, sometimes that helps (but I dont know)...
