MeanGreenS13 wrote:614 and only 10sec? your not much of a drag racer are you...
450 will put you into the mid 10s with right suspension, gearing, DRIVER and weight.
You need to go do a little more research it sounds like.
Ill be damn close to 450 when im all said and done here... so maybe ILL be one of your competitors =)
I hope you Whp i don´t?I had 316whp with stock bottom and run
60fot=1.75 201m=7.79 147km/h402m=12.13 182km/h
Stock gearbox and welded diff and M/T 10.5x26-15
And please tape it when you run mid 10s with 450hp manuell gearbox.
