Working under Plenum....
pabs324
Car: 94 Q45
Is the best way to prevent hydro-locking to pull the fuel pump fuse while the car is on and make it stall?
Modified by pabs324 at 12:16 AM 5/2/2008
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
Q451990 wrote:PB Blaster is a release agent similar to WD-40, but seems to be the prefered one. Heath
If you can find it, this stuff makes PB Blaster look like calgon bath oil.
I recently replaced all the bolts on my boat boat trailer and NOTHING would loosen them so I gave up and fired up the sawzall. My slip mate showed up and handed me a can of this....all the bolts were free after one quick squirtMy trailer dunks in salt water 2-3 times per week and is 7 years old if that gives you an idea of the level of corrosion.
http://www.kanolabs.com/
Expensive but worth every penny.
91-q45
Car: 1991 infiniti Q45
if im not mistaken, isnt hydrolocking when coolant floods the cylinders?
oldmako
gas on these mothers....
of course, coolant is always a possibility, a very uncool possibility.
Q45tech
Maybe we should invent a more descriptive TERM:PetrolockBenzinlockGazlockingIncompressible liquid locking
But then again we are hydral not hydro
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Hydrolock
From Wikipedia, the free encyclopedia
http://en.wikipedia.org/wiki/Hydrolock
In automotive terminology, a hydrolock (short for hydraulic lock) is the immobilization of an engine's pistons by a liquid (usually water, hence the prefix "hydro-"). Hydrolocking occurs when liquid fills a cylinder on the intake stroke and, due to the incompressibility of a liquid, makes the compression stroke impossible. This, in turn, prevents the entire engine from turning, and can cause significant engine damage if one attempts to forcibly turn over or start the engine. Typically, connecting rods will be bent, making the engine uneconomical to repair
[edit] TreatmentRegardless of the cause, treatment is the same. Removal of the spark plugs will allow access to the combustion chamber. By inserting an irrigation syringe fitted with a flexible plastic tube on the end, you can suck out the liquid that infiltrated the combustion chamber. Once all the fluid is removed, the chamber should be sprayed with a liberal coating of a water displacing lubricant such as WD-40, and allowed to sit until the remaining water has evaporated. Once the water or coolant has been removed, inspect the combustion chamber for rust. The best option would be to remove the head, but a borescope or small flashlight and mirror will also work. Light surface rust will be normal, but if you see any heavy corrosion, it should be gently removed, and vacuumed out of the chamber. After inspection, pour a tablespoon of assembly lube (such as Marvel Mystery Oil) or clean engine oil into each combustion chamber. Attach a socket to the crankshaft, and slowly rotate the engine through a few revolutions. (Make sure that you turn the engine in the proper direction, see a service manual for proper rotation direction.) If you hear any clanking, or harsh scraping, you should bring the engine to a competent mechanic. After verifying that the remaining systems are free of water (electrical, fuel delivery, air intake, distributor, etc.), re-install the spark plugs and wires, and attempt to start the engine.
SeaFoamSome people have stated they think Seafoam can Hydro lock their motors. Used correctly this cannot happen. When drawn through an intake vacuum hose into the intake, and dispersed with air amongst all the cylinders, there will not be enough liquid in any one cylinder to cause enough incompressibility. For example, a Ford 4.6 liter V8 can hold (up to) 575 milliliters of fluid in each cylinder. 1/3 of a 16 ounce bottle of Seafoam is 158 milliliters.
Q45tech
a hydrolock (short for hydraulic lock) a liquid (usually water, hence the prefix "hydro-")..
That's the exact problem using hydro for water instead of hydra............the error is in using the o for an a. When HYDRA-LOCK should be used when referring to gasoline or oil.
Unfortunately the public may not know the difference.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
91-q45 wrote:if im not mistaken, isnt hydrolocking when coolant floods the cylinders?
Any non compressible liquid. Coolant would additionally indicate head gasket failure, something that never happens on a VH45DE unless overheated.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The real question is why would one resort to a palliative like Seafoam?
pabs324
Car: 94 Q45
what is best way to prevent fuel from entering the engine when working under the plenum....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Read the posts.
While engine is running at idle, remove fuel pump fuse. Release fuel filler cap.
pabs324
Car: 94 Q45
I did read that post and was just making sure that was the best way. should i then proceed to take the engine through a few cranking cycles or just let it stall after removing the fuse?
But thanks Maxnix thats the most straightforward post to that question
96Qowner
Car: 1996 Q45
Just let it stall.
But that usually doesn't take all the fuel out of the rail either - you'll still spill some when you mess with the lines, so have plenty of towels to soak it up.
pabs324
Car: 94 Q45
ok sounds good
Q451990
The best way to be sure fuel doesn't spill from your fuel rails into the runners, is to remove them as a unit. Then pull the injectors from the rails on a work bench.
Heath
pabs324
Car: 94 Q45
Ok. That's how I was going to remove the injectors.
That's the biggest thing I'm worried about with this project
