Working on my suspension
Vanessalalinda
Car: 1990 Nissan 300ZX
So i just got my Z n/a a couple of weeks ago and tis a bit of a rough ride lol especially with the horrible city roads of Newark and Jersey city. So now i have to find a good Z shop to check it all out and invest in its suspension system. Now I'm very new to the mechanic scene since with a honda civic the only thing i had to remember was to change the oil. Any idea how much the upgrades will cost me? and how much better can the suspension system actually get?
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
You can make the suspention great on a Z,
It will still be rough beacuse it will be so tight, but your going to spend alot of money haveing a shop install new springs and struts, prob close to $1200-1500 with parts and labor
ive got Kyb adjustibles on mine with a 0.8" drop and my car feels very firm and tight around turns
You can also get some adjustiable tention rods to adjust camber or caster since it isnt adjustable on a z and they are very hard to align
id make sure all the bushings and joints are tight and dont have play in them, even if you repalced everything with OEM parts they car should ride very nice and tight like a true sports car should feel (without turbos)
Vanessalalinda
wow that's a lot of money- How much do you think id spend if i did it myself? (that is have my dad do it and hopefully learn how to do it myself lol)
NissanFairladyZ32
On Springs and Sturts around $300-600
Depending on quiality of product
Chase300
Car: 1990 300zx TT
Vanessa i just bought a tt last week and im getting the out of province done. i needed to replace rear inner tie rods as well as the outter tie rod ball joints. i needed new rear shocks and front tie rod bushings. then once replaced i will need an alignment. and i need new front rubber. the shop quoted me 2800$ i told them to F off. I just ordered kyb ajustable shocks front and rear, new front tierod bushings, new rear inner tierod and the outter balljoints. This costed me just under 800$ new rubber will be like 300 more. all in all 1100$ vs 2800$ is well worth it to do it yourself and if you know what your doing it should take roughly a day or 2's work. fyi.
Vanessalalinda
jeez these shops are nuts! ill def have to do it myself...
NissanFairladyZ32
Just wait till you have to do engine work at a shop, there will charge you so hard you wont even see it coming
Timing belt/ Waterpump $1500-1800
Injectors $600-1000
For people who are not mechanicly inclined it sucks shops will change 80-$100 for sparkplugs that can be done in 30 mins
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
Cheapest route to go with upgrading suspension is to do tokico hp's $275 on ebay eibach springs can be found used for good price alot of times and the 300 degree camber kit $80 then do it yourself it's not hard to do just need a spring compressor and tools.
labcoatmonkey
Car: 1991 300zx JDM TT I miss u 01 alty
Also to add to that, you want to look into installing strut braces... front and rear. It will give u a noticeably firmer, not so rattly ride. Does great around turns too
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
^ you mean sway bars.
Vanessalalinda
ok which is it lol.....i def would like to reduce the rattle..
car nut
Car: GT500.
What you really need to do is make the chassis more rigid. A rigid chassis will transfer bumps in the road to your springs and dampers. To really get rid of all the rattle, you need a complete overhaul. Coilovers, bushings, sway bars and strut tower bars. Then since your call will be lower, you'll need tension rods at the very least to correct your alignment. I'd also suggest foam injection, since it will really stiffen up the frame of the car.
But that all costs a lot of money.
I'd look at bushings and sway bars first, with strut tower bars and coilovers later. Z's with fully built suspensions ride better than stock Z's because they have very limited chatter.
Vanessalalinda
Thanks!!!!
andrez
Car: 1990 300zx na / 1995 f-150 4x4 / 05 focus xr4 99 blazer s-10 jacked
down to the bones it will cost you parts and a case of brews for your dad....and you better clean the house or something.........if you are really smart tell your dad "a dollar for every time you swear" you might get your money back ...this cars will bring it out of him for sure
Vanessalalinda
that's so funny cuz he doesnt swear or drink and we don't live together hahhaha...although i have a feeling he's not familiar with all this so i'm not sure what to do..
OUKNO
Car: 1990 Z32 NA, 1974 International Scout
heres a link to some Tokico struts with springs 300freekzx has found these cheaper ask him wherehttp://www.racepages.com/produ...11374
here are a couple links to help with install & allignment1st~ is your needed camber adjustment kit (so your not driving on slicks in a month)http://www.twinturbo.net/nissa....html2nd~ is strut/spring installhttp://www.twinturbo.net/nissa....htmlthe ride is definitely tighter with good springs & struts but Z32's handle so much beter with good suspensiongood luck
Vanessalalinda
Thanks!!!
NissanFairladyZ32
Just buy some nice wheels
