working HUD with an SR20 ?
crapanese
Car: s13
my hud is broken ( big suprise ) but i really like it as an option on my coupe. is there any way to make this work with an SR20 ? or should just get get an analog setup. is there a write up on how to fix the HUD ? ? ? or is it easier to just find another working cluster ?
sorry if this has been asked a ton, i searched but came up with no good information
moulton712
Car: coupe, hatch, both s13s
i don't know the answer but this might work.
the hud has a switch you can change from mph to kph (not like the analog where you need to swap a resistor).
and if you can get the hud to work by itself. by tring this
zerothread/158878
then i don't see why you couldn't get it to work.
elo240
A HUD will work just fine with a sr20 as long as its from a Dual Cam engine. I have one in my car and it works fine.
crapanese
Car: s13
elo240 wrote:A HUD will work just fine with a sr20 as long as its from a Dual Cam engine. I have one in my car and it works fine.
is there any way to dicypher if the cluster is a SOHC or Dual overhead cam ?
did the SE model coupes come with a SOHC ??
im kinda a noob at knowing trim level options, but im learning. haha just trying to get my broken HUD to work in my coupe with the SR20 thats in it...the heads up display is a sweet *** option, idk why people would want to not utilize it
elo240
89-90 cars were sohc. 91-94 were dohc. I don't know what year your car is. As for determining by looking at the cluster I don't know.
silly805
Car: 240sx RPS-13
my hud works with my red top it plugs right in prefect. i also heard as long its a dohc it'll work
crapanese
Car: s13
awesome. thanks for all the info guys
