This is my experience after following that famous DOHC to SOHC tutorial with no pics that everyone seems to have problems with. It worked for me after some ghetto rigging....
I just bought a 89 240sx with dohc motor. The digital HUD cluster SOHC tach didnt work. I wired my TAM to the ignition coil plug and it worked. This is how I did it.
Tools-Screw driversSplicerWire
1.) Pull out your cluster and find the yellow/red wire. If you can't find that then look behind cluster on the wiring board and it should say TAM on one of the cooper leads. There should be a screw attached to that lead. Follow that to the harness and that's your yellow/red wire. Now that you've located that wire we can move to the next step.
2.) Go to the engine bay and locate your ignition coil. The ignition coil has two plugs coming into it. One plug goes to your distributor and looks like a spark plug cable. IGNORE that. The other side is a 2 wire plug/harness. That's what your looking for. This is where it gets funny....The original dohc to sohc tutorial u followed says to splice into the positive. Well either I didn't splice into the right one or the tutorial is wrong but when I did this the first time it didnt work. A local mechanic told me that my tach should get signal from the negative of the coil and not the positive. Well basically what I did, was i tried both sides and one side worked.
3.) Once you've located the ignition coil harness and the TAM then you will need to connect them together with a wire. You have two options with the TAM side connection. You can wire it to the screw connected to the TAM cooper board lead. Or wire it to the actual yellow/red wire. (I screwed it in to the TAM screw on the board and snipped the yellow/red wire.) Then run that wire through your firewall to the ignition coil harness. Once you start your motor u should see your tach kick in. If you dont then try the other wire on the ignition coil. I know this is kinda ghetto but I GOT A WORKING TACH NOW!!!!
COST=0
