do you know anyone that does this? cutting/welding i assume?jr_ss wrote:You need the Sr compressor, the KA will not bolt up. Use the KA line, cut the end off and have the Sr end put on it. The harness will plug right in to the Sr compressor. You shouldn't have to do anything with the compressor to Evap line, should both right up.
Let me know if you have any questions, mine works flawlessly...
