datsun2401972 »
https://forums.nicoclub.com/datsun2401972-u41045.html
Thu Mar 29, 2007 10:48 am
I have KTS on my s13 and I think it's bumpy...too bumpy for my comfort anyways. If your like me, you probably won't be satisfied with any coilovers unless they are individually adjustable for low compression, high compression, and rebound. Or you could just try lowering the spring rates...
BTW Kenny, my s13 didn't need toe arms after I lowered it. But I had a good alignment man line it up for me too. If your mechanic can't line it up with typical methods of alignment, ask him if he played with the inner mounts on the lower control arm. That's what my guy did....and I've had no wear problems with -1.5 camber and around 1/16 toe in on the rear.
Experience with this setup: the limit of adhesion is easily predictable, mid corner the car will rotate with a lift of the throttle. I feel a little understeer in tight low speed turns, but that may be worked out when I get sway bars. Keep in mind my car is an all stock ka24e with no chassis mods other than KTS coilovers and SPL rucas. My coilover settings are 8 up front and 10 on the rear stiffness, but I'm sure that won't matter as Ksports are probably valved differently...hope this helps
eh...forgot to add I have an open diff...
Modified by datsun2401972 at 5:51 PM 3/29/2007
