WOOT!! 5spd conversion on the way!!
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
yes yes yes, i am going to convert the old slush 240 to a 5spd and i can't wait. i'm getting everything except the driveshaft, engine backing plate, and hydro lines for $350 shipped. he said he thought he had the slave cylinder, looked for it, couldn't find it, determined it lost, and graciously went out and bought me a BRAND NEW one at NO EXTRA COST. that was so awesome!! i have everything else i needed sourced, just have to rebuild my monitary funds. i owed my parents some money unfortunately, otherwise the other parts would also be on their way. i plan on selling the clutch that comes w/ the conversion. its an OEM with about 1000 miles on it. so i will sell that and whatever else, and i am going to buy an ACT Street or 6puck. i'm still trying to find a 300zx shift knob for cheap, but am not having luck. i'll get a new one probably. my b-day is in a few days, so i'll be gettin money well, i'm very excited so i thought i would share
P.S. me, cnichols, redrocket and former_240_s14 are all most likely going to be doing the install ourselves. wish us luck.
P.P.S. any recomendations on transmission fluid? Redline?
Lepchitz1
Car: Cars, and LESBIANS!!!
hey congrats ben, i have mobile 1 sythetic gear oil, and it works great! G/l with the install...its not too hard :)
encasemyheart
Yeah good luck, look forward to shaving a second off of your quarter. :)
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
WOOOOOOOOOOOOOT!:D :rotflmao lol CONGRATS BRO!
-Dan
UncleBen
yea boys i'm wanting to break that dam 16.6. thats pathetic. i can't wait!! hey will, you wanna drive up and help? :D j/k. i gotta lota people coming to help w/ it thank God.
slw240sx
Car: 1990 Ca18det 240sx Hatch
good luck man, im still goin to whoop on yah when i finally get my car to make it off my street !!
UncleBen
yea, but until then......
optiks
what was all needed for the swap im thinking of jus getting a 5 speed parts car
UncleBen
u can find all of the parts from http://www.240sx.org/installs or sumthing like that. just go to 240sx.org and go to the installs page and find the 5spd swap. but basically you need these things as far as parts go: transmission, FSM, shifter, engine backing plate, clutch, pressure plate, release bearing, new flywheel bolts (the 5spd ones are longer), driveshaft, pedals, clutch master cylinder, slave cylinder, and then just the shift boots and stuff. i don't think i forgot anything
Dano
a shift knob! :pface :D
-Dan
574-240sx
Car: Nissans, Toyotas, Subaru
I just did the conversion. I am having alot of problems with the clutch engagement point. I seem to get it right and it feels fine them the next day i go out its hard to shift and i have to readjust the petal. And if anyone knows, i need to find the wires to hook up my reverse light from the sensor to the connections by the battery. Currently i don't have a transmission wiring harness. I have so far bypassed the neutral saftey switch and coneccted the speed sensor. Nick
Structure240sx
i'm in the same boat as you 95silviase, i jsut need a driveshaft (ABS). Is the palte between the auto transmission and engine the engine backing plate your talking about? is that really neccessary? i just pulled my transmission out the other day, its a heavy ***** good job gettin people to help you. what r u goin to be doin about wiring?
UncleBen
wiring, dunno. we'll figure sumthin out. and the plate IS necessary for the swap. you will have to get one from a 5spd 240.
574-240sx or whoever, lol, do you have any pics of your install? any pointers/thing to look out for? anything will help!!
daniel240
Car: cars/motocross
good luck with the install. your going to love your car so much more.
574-240sx
The hardest part is drilling the hole for the master cylinder. Yes it is a pain getting to the bolts for the auto transmission. The manual goes in much easier and there is much more room to work. I did all of this on my back in my garage and the car was out latter that day with the help of a friend. You will find it easier to jack up the transmission to pull all the bolts up the top of the transmission. Plan to get you flywheel resurfaced and put lock tight on the flywheel bolt and torque them down to 105ft/lbs, as i found out. You don't need to replace your brake petal just cut it down and place the rubber cover piece over it. Nick
Structure240sx
yea the bolt on the very top is a pain in the ***. makes sure to take off the torque converter before u try to drop the transmission. i forgot about that step from my FSM wasted 45min
slw240sx
ben the removal and installation of those two diff brake pedals is a total pain in the arse i had a guy do one last week and he said after all is done he would have prob just cut the pedal down.. i told him about that trick after he was finished he wasnt to please finding out there was an easier way then droping the coulmn and taking apart some of the dash and removing the seat
574-240sx
remember before you put the manual transmission in take the torque converter bushing out.
UncleBen
574-240sx wrote:The hardest part is drilling the hole for the master cylinder. Yes it is a pain getting to the bolts for the auto transmission. The manual goes in much easier and there is much more room to work. I did all of this on my back in my garage and the car was out latter that day with the help of a friend. You will find it easier to jack up the transmission to pull all the bolts up the top of the transmission. Plan to get you flywheel resurfaced and put lock tight on the flywheel bolt and torque them down to 105ft/lbs, as i found out. You don't need to replace your brake petal just cut it down and place the rubber cover piece over it. Nick
this is very helpful dude, for real! i am not understand the part about jacking up the transmission. you jack the auto transmission up farther and it makes it easier to get to the bolts?but those are some very helpful hints, thanks alot!
Toahk
Car: 97 ....
Hey are you looking to get rid of your old auto transmission? if so email me [email protected] please, im very interested, my transmission just went and im looking for another.
UncleBen
heck yea i'm interested in getting rid of it. it has 119,xxx miles, shifts perfect. shifts hard when hard on the gas. i've never had a problem with it. i have no idea when i'll be doing the actual swap though. how soon do you need the transmission? my swap won't be for another month, month and a half i bet.
574-240sx
Quote »i am not understand the part about jacking up the transmission. you jack the auto transmission up farther and it makes it easier to get to the bolts?[/quote]
disconnect the drive shaft and crossmember. Yes i ment jack the rear of the transmission up till it stops. It will tilt the engine away from the firewall so you have more room to get to the the 3 bolts at the top of the transmission and the starter bolts on the auto you are pulling out. Or you could do it the hard way and use 5 feet of extentions and universal knuckels. Nick
UncleBen
no no, i'll do it the easy way. thanks :)
UncleBen
i just remembered, have you found out the problem with your clutch not engaging sometimes?
Toahk
Car: 97 ....
Keep me updated on the transmission im interested in it, when you get your swap done of course. =)
UncleBen
sounds good. i'll definately keep you in mind.
Dano
if i can get all the 5spd parts, ill be gettin rid o my auto transmission too, but dont look at me anytime soon, no $$....grrrrr Ben, i know u have a job....but making those "brand new big subway sandwiches....errr...check ure mail from Rob...HAHAHA LMAO :rotflmao LMAO!
-Dan
