bokinsmowls »
https://forums.nicoclub.com/bokinsmowls-u16207.html
Fri Jul 02, 2004 2:54 am
I just followed the FMS to the T. Except for I didnt take the subframe off like it said. Just left transmission mount attached and jacked up motor at the the bellhousing to get enough room to get the oil pan out. The trickiest part is getting the oil pick-up off and back on with out messing anything up. It has to come off before the cover or oil pan will come off. If all your talking about is the upper guide, you should be able to just take the valve cover of and remove it. Only have to buy a valve cover gasket.GL SunshineAcid, it IS a pain.
