The carstereohelp stuff is still there.
http://carstereohelp.com/stere...o.htm
There's not much to removing the bezel. Follow the instructions on the link above. The main thing is that the two top retaining clips are VERY tough to undo. Don't force things. The first time I removed the bezel (it gets easier after the first time) I thought I was going to snap the bezel in half.
What finally did the trick was to use a hool tool to pull on the top of the bezel. There are two clips about 1 1/2 to 2 inches from the left and right top edges of the bezel (above the AC controls). Look at the fourth image on the above link. The clip location is marked by two red rectangles.
Anyway, it helps to slide a hook took behind the bezel where those clips are located and give it a firm pull (straight back) and the bezel will pop right out.
Here's the tool I used for it.
http://www.sears.com/sr/javasr...13000
Good luck.
Carlos
