Woo Hoo! Passed California Smog. Results inside.
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
1992 Q45
Speed %Co2 %o2 HC(PPM)~Avg Co%~Avg NO(PPM)~Avg15mph 14.9 .3 40 31 .07 .10 250 237
Speed %Co2 %o2 HC(PPM)~Avg Co%~Avg NO(PPM)~Avg25mph 15.0 .1 23 20 .06 .09 336 199
Passed with flying colors, Way under the maximum limits.
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
What smog test. No such an animal here in FL :-)
Rex
Car: None
chinaonnitrous wrote:1992 Q45
Glad to hear, but was there any real concern it wouldn't pass?
On a somewhat related topic, I've always wondered what good/clean numbers say about the overall health of the motor?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
wow... i thought jesdas Q still had a bad injector..... Impressive.....
I remember tech saying that this car gives off so little CO that you couldnt kill yourself if it was well maintained.
chinaonnitrous
Rex wrote:Glad to hear, but was there any real concern it wouldn't pass?
Never really doubted the car, although it did stall twice yesterday after semi-hard braking.... *shrug*
But I would think, that a clean run on the smog test will indicate, that most sensors are up to par, doing their job, and the motor is relatively clean inside (valves etc....)
Elwesso wrote:wow... i thought jesdas Q still had a bad injector..... Impressive.....
I was thinking there might be one that was bad/going bad because of the intermittent vibration whthin the cabin. But, since the front upper links are so badly worn, I'm still betting, its the transmission/engine mounts first. It does happen at about 1500~2100 rpm. Or could even be the old front tires put on the car.
hazw8st
Thats good for a Q45....
