Wont turn over
oLemurs
Car: 2005 Mazda 6, 1978 Buick regal, 1993 240sx
So i finished the battery relocation today and after i connected all engine grounds i tried to start it, as you can see the car has power but the fuel pump wont prime (im going to take it apart to see if its good or not) and when i turn it to start i can see the lights dim but the engine wont turn over, could this just be a bad battery? its a refurbished battery from 2016 and i just recharged it for 15 hours. what else should i look for fixing because im super confused. BTW its an sr20 swap
https://www.youtube.com/watch?v=PWFYBNs ... el=oLemurs
oLemurs
oLemurs wrote:
Sun Aug 13, 2017 1:53 pm
http://imgur.com/a/mRSZn
MarkSilla28
Car: 1990 nissan 240sx s13 with a 1996 ka24de
Try putting some jumper cables to see if it will turn over like that
oLemurs
MarkSilla28 wrote:
Mon Aug 14, 2017 12:05 pm
Good idea
oLemurs
So i just got a new battery hoping it would help to turn the engine over and it didnt help anything, so i took out the starter and while i was down there i saw this plug and didnt know what it went to so i took a pic http://imgur.com/gallery/ltNFu i was looking into how to test an sr20 starter and i saw a picture with a wire coming OFF of the starter solenoid. the only wires i had attatched to my solenoid were the ground and 12v from the battery, is this plug what i need to get the engine to crank over? if so do you know where i can buy the wire for it?
Reason: Merged with existing thread
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
oLemurs wrote:
Sun Aug 20, 2017 4:53 pm
Thanks for the update. As you already had an open thread for this topic, there was no need to start a new one. Merged.
