WONT STAY CRANKED
street2nr
Car: 1993 Mazda RX7 1996 Nissan 240sx
This has probably been asked b4 but i cant find the solution. Well i brought this RB20 powered 240 off this guy for 2500 bucks.. the car cranks and runs at idle but the second you try to give it gas it dies on you..
I need help ASAP, gotta get this project running!!!!
Carl H
unplug the maf and see if it runs...if it does then its either an intake leak or a bad maf.
street2nr
Are you sure about that solution? Sounds like the best one i heard yet! well im not around the car and cant wait to get back to it! i gotta test it out!
BoostFab
Car: S13cp, S13fb, S14z
street2nr wrote:Are you sure about that solution? Sounds like the best one i heard yet! well im not around the car and cant wait to get back to it! i gotta test it out!
there's never one sure solution, that's why it's call "testing" it.
check your fuel pressure, where it's sitting at?
street2nr
really im just tryn to avoid expensive repairs, i beleive its something simple and hoping thats all it is.. ya kno..
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
The reason you unplug the maf is to put the car into limp mode. It will run off a preprogramed map off the ecu. You won't be able to rev it out past 2500 but the car should start up and idle. If it still doesn't then there is something else wrong.
