DriftX »
https://forums.nicoclub.com/driftx-u61933.html
Tue Apr 08, 2008 4:07 pm
It looks like that brown wire is for the power steering switch. All i can find in the s13 fsm is brn (brown) is p/s pressure.
Edit: After looking closer, Under "Engine Contol Wiring" in the s13 fsm, a brown wire is used for the winshield washer switch.
this brown wire controls your "wiper amp" . So perhaps your wiper motor is froze up, or your switch is on/stuck for wipers and pulling a hella lot of amps, blowing your fuse.
unhook your wiper motor and see what it does, although i don't think that's the problem.
Also using a brown wiring is the clutch inhibitor switch which is probably the cause of the fuse problem.
As judging by the diagram, brown is the hot side of the coil on the relay, on the other side is ground. So it is possible your inhibitor relay is welded closed.
Try swapping out your clutch inhibitor relay and let me know.
Brown wire is also used for power off the retract relay for your seatbelts, possibly you could unplug the power belts module under the center console.
That is all the brown wires used for the s13. Let me know what you find.
Modified by DriftX at 7:20 PM 4/8/2008
