Wont start when hot??
sick240
Car: 91 240sx coupe
Hey all,
I have a 91 240 coupe with an sr. The sr ran perfect until i pulled it to paint the bay. Now it does not start when hot. Any help will be very much appreciated.
Issue:Cold start is fineAfter 20-30 mins Idle, turn off then try to start and it wont startChecked for spark and no spark (At time of problem)Checked for grounds and all "seem fine"Checked ECU for proper connectionBefore i pulled sr the temp gauge worked, now it does notCar cools for 4-5 hours, starts fine
SOS!!!
RinseCycle
Car: 95 S14 w/ Redtop SR20det (stock)
does that vehicle ever cut off on you after it gets hot? or is this only a starting issue?
CrypticScorpio
Car: 1992 240sx SE Hatch
check ur temp sensor.
silvia tech
Car: s13, s13, sentra, ford truck
second the motion to check your coolant temp sensor.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
+3 for coolant temp sensor.
Fahaka
Car: '96 S14 '07 Versa
replace or clean your o2 sensor.
sick240
Car: 91 240sx coupe
Thanks for the replies, i didnt get an email notification on replies...I will definatley try the coolant sensor. Will that cause it to not give spark? Is that an expensive part?
Thanks again.
positron1
A coolant temp sensor from Autozone will cost you $20 bucks give or take.
