Wont Start
ScottnAshley
Car: Cars, Computers
I was driving to work and as I exited off the highway the car stalled out I tried starting it up it turns over but wont start I have a new starter and battery. Last night it took a while to start but started. Any help is appreciated because she is stuck off an exit.
slo40
Are you sure that you are getting fuel?? Or have you ran a spark test on it yet??
ScottnAshley
i went back 10 hours later aftrer work it it started fine but has thing weird smell i cant describe it and my belt squeaked maybe its just teh flywheel belt its to loose and it cant start possibly? is it possible to blow a fuel injector?
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
injectors can get clogged, fuel pump fails... or other minor electrical problems
slo40
UMMMMM WTF is a flywheel belt?? lol Pretty sure the flywheel just has teeth going around it that connect to the starters gear. Also you said it was cranking so therefore everything in the flywheel area is working fine.
ScottnAshley
i dunno lol im new to these engines i use to fords lol.
