Check the wiring to the fuel pump and make sure the connector to the Fuel Pump Control Unit (FPCU) or the Fuel Pump (FP) sending unit is not burned or otherwise bad.
Do you have a aftermarket alarm or kill switch for the Fuel Pump installed?
Grounding the Fuel Pump makes it go into full speed mode all the time(43.4 PSI) VS (34 PSI under certain conditions).
Attach a alligator clip with a wire to a suitable ground (unpainted, low resistance...) as shown in this picture courtesty of Mike (goody90Q45):
Or you can do like I did and find a suitable female connector for the Fuel Pump Control Unit connector and plug that into it and the other end to a suitable ground.
The search has gotten better and I guess it takes practice like with everything. But if the search didn't work how else would I be able to put some of this together:
https://docs.google.com/leaf?id=0B5VDQi ... N2I3&hl=en
