AZ89two4Tsx wrote:Could possibly be the neutral safety switch.
It's a little switch that makes sure you have the clutch pushed in, when starting. You'll have to get way under there to see it, but it's there.
Clutch safety switch was removed awhile ago. Thanks though.
SilviaMike wrote:stupid question I know but (assuming its an SR swap) it happens alot with SR swaps with people that dont swap the plug or solinoid.. you sure the signal wire didnt come unplugged?
The starter came with the motor-set, so nothing needs to be switched. It is a SR starter/solenoid for sure.
But what signal wire are you talking about?
What's weird is that the car started fine up until that point.
