Wont Start, fuel pump fuse blowns after each crank.
hotsteamrice
Car: 240SX
First of all thanks for checking out my problem...Anyway I did searchs but nothing about blowing fuses. Just new starter and etc.
The 240SX wont start. I replace the Battery, Starter, Spark plugs and wires.
Everything lights up inside the car. Everything looks like it works... Except it wont crank.
When i try to crank it clicks once. Sometime it looks like it wants to turn over but that only happen really short.
Each time I crank it the fuse for the fuel pump blows out.
The car is 1989 240SX 5 speed.
I read one topic about a fuel pump but i dont know...im a newbie... thanks for you time and help.
*I did a search for wont start now im doing a search for blown fuse..*
180fan
Car: 89 fastback
did you replace the fuel pump recently? Something is shorting out your fuel pump and now you gotta find the lil bastard that's causing it.
Do you have a multimeter?
did the car start up ok before it blew out (hence the need for a new starter)?
vancouverbc
Car: 1991 240sx
the starter is just a motor. it only needs ground and 12v+ to start. it has constant ground and gets 12v+ when you turn ignition key to start. there is a relay by battery that interrupts 12v+ going to battery but that is how simple the circuit is.Unplug the connector at the starter and check to see if 12v+ is getting there when you turn key to start. make sure battery cables are tight.
