Wont rev? Gotta Idea
fullkit_s13
Car: Auto paint
Well heres the deal I replaced the engine and now the engine starts really hard and to keep it running it has to be floored, but when its floored it only revs to 1k
Could it be a vac leak
NISTECH
or a bad MAF or siganl from it,or a serious injector leak.
navysnail
is there alot of black smoke or any color smoke coming out of the exhaust??
fullkit_s13
Car: Auto paint
normal engine smoke
NISTECH
also could be seriously out of time
fullkit_s13
Car: Auto paint
one Major Question
HOw do I set the timing?
navysnail
you need a timing light. you hook up the 2 aligator clips to the battery, then you hook up the 3rd to #1 plug wire, crank the engine, point it at the crank pully, you will see the timing marks, set it to specs, they should be on the underside of the hood
fullkit_s13
Car: Auto paint
Your really funny.
fullkit_s13
Car: Auto paint
BUt the real deal is that come to find out the #1 cylinder had a crack in the top of the piston and it finally blew a hole and got jammed in the crank and threw a rod.
Sooo if yah know where I kan get a ka24de for around 600$ that would be nice
thanx and it was the timing that was way off
NISTECH
sounds like you tagged a valve since it was so far out of time. that is likely what blew the hole in the piston.
I dont understand your "Your really funny" post. He gave you direction on how to check your timing after you asked?????
fullkit_s13
Car: Auto paint
Well thre is a new problem I got a new engine and now the clutch is really low and i dunno what is up, and how do i properly bleed it
Touchdown038
Car: Computers, cars, sports
Did you install either of these engines yourself? Because I should hope you would know how to bleed anything if you did it yourself.
Same as bleeding brakes. Pump, hold, have helper open and close bleeder valve. Repeat.
As for the clutch pedal height, a search would have revealed that there are two nuts on the clutch fork that you can adjust to make the pedal higher and lower.
fullkit_s13
Car: Auto paint
Well i bled the crap out of iy and still the clutch is constantly engaged i cant figure it out
corn322
Car: 1993 240sx
dont' forget to bleed both the slave cylinder and the dampner line.
