PabloHoney wrote:240's have a 5th gear rev limiter at 5100 or so. It is a pretty violent shake that happens when it hits too. So..... maybe the 5th gear sensor in your transmission is stuck on. My suggestion: try unplugging the 5th gear sensor on your transmission and see if it still happens.
You dont know how Happy I am.
The 5th gear switch was my problem. My "red line" just increased by almost 2000 rpm
My car drove fine in all gears with no 5th sensor, is it only there for the rev-limiter? Is there any reason I should replace it, and not just leave it disconnected?
