Wont rev above 4000 rpm
clever240sx
Car: Nissan 240sx
I have ANOTHER problem. I was at the local oreilys yesterday and when i was about to leave i started the car up and it wouldnt rev above 4gs. It would just bounce off 4000 and continue to to not go over 4000. I just got a video of it doing this. Also it will idle at 3000rpms.
Heres the video:
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
I have the same exact problem but except it doesn't idle that high. I'm guessing 1100 or so. How did you fix your tach? I see its a SOHC tach?
Try this link:
http://forums.racebread.com/index.php?topic=636.0
I just changed my spark plugs since they were gapped wayyyyy to high. I hope that fixes the problem. I haven't had the chance to see.
Shocker
Car: 89 240sxHB rb26/30
check your base timing.
Carl H
bad coolant temp sensor.
clever240sx
Car: Nissan 240sx
Nismo Z ilvia: That was a great link!....i did notice the cover for the ignitor was cracked. Would that be the problem? I just changed all spark plugs and the oil. Still nothing. Now im going to check the MAF sensor and wiring.
nizmo zilvia
Well I just changed my plugs and it helped very little. Im going to see what my ecu tells me now. I bet now its my TPS or could be my CAS.
nizmo zilvia
Got 5 long flashes and 5 short flashes which means everything is ok.
Carl H
if the ignitor is in any shape way or form damaged then usualy its dead.
clever240sx
Car: Nissan 240sx
I fixed it. My MAF wires were melted together. They got too hot sitting by the turbo. SO i tapped them up and set them in a different place!
Thanks for the help guys!
