chicos240 »
https://forums.nicoclub.com/chicos240-u20799.html
Mon Mar 08, 2010 7:14 pm
Check your grounds.For your engine to crank you need very few things.1) Battery2) STarter3) Wiring4) ground
If you do not hear the "click" that means your relay is not being told to activate. Which in turn does not complete the circuit at the starter, so your starter does not get the juice to start. So check your wiring..... Check your grounds, You can also try whats on page EL-31 ...of the FSM
