Wonky idle
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Dattebayo
I just got this SE-R, and everything seems to run fine, but it seems a little sluggish in the low end (I'm used to a VG30 tho....) and the idle isn't very stable. It seems to rise and fall from 500 rpms with occasional stability up around 700.
Think this could be a vacuum leak or possibly something else?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
yes it could be vacuum. Have you inspected all the items for wear that are involved in the general tuneup yet?
Spark plugs, dizzy, oil,
throttle cable tight?
TPS?
I can give more and more suggestions if you want.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
