jdmser »
https://forums.nicoclub.com/jdmser-u10477.html
Sat Jul 15, 2006 3:27 pm
I looked up the plug your talking about, but I can't tell all the wire colors in the picture. There should be 7 wires going to the plug with the top right spot empty if your looking at the side where the wires come out. There should be G/OR=neutral switch, LG=A/C relay, SB=P/S switch, W/PU= Power to ignition coil relay, B/R Ignition switch(on signal), WB Power to ECCS relay, injectors, and backup power to ECU. I cut the plug off a long time ago or I would take a look at it for yah. Hope this helps.
