mac, gothcha so your open to change - here's what I did in a VG30DE -eng. supposedly VERY sensitive to Alt.plug replacements . I installed NGK IX type ONE COLDER (AZ gets 119'deg.+) - that allows me to go an extra couple degrees Adv. timing(even in that heat) , much better response, noticeably better power - basically Irridium is noted "under stressfull heat conditions " to cause reduce Knock potential , thus reducing/lowering the "Retard Band parameter" , basically ECM' Ign. mgmt. is NOT RETARDING AS much / AS often - to a significant enough degree as to be VERY NOTICEABLE
Biggest rewards , again - under harshest street running/ high - AMB. & Eng. temps!! You may come across many valid sounding discussions that NO plug (alone -NO SH%$&@TT) ever will get you ANY noticeable difference in performance - what's left out of that theory/discussion is Some plugs ,like Irridiun, can ALLOW - SYMBIOTICALLY OTHER Adj. , & parameters to achieve a MORE POWERFUL POTENTIAL usually through further - radical adjustment or "MODS" etc.,etc. = END RESULT ,yes NOTICEABLY better performance!!
ONE PARTICULAR unique plug design CAN far surpass the achievements of what various other plug choices may yield. END of discussion
TUNING
