aww dam my bad typo. and can i use a z32 brake booster for the j30 setup?zachattack_5491 wrote:I don't know anything about the rear. But the fronts are strait bolt on. You need to trim the dust cover for the rotor, and then you're done. And for 4 lug, you re-drill the ROTOR not the caliper.
Yeah the thing with the liquid is the brake master cylinder. That's what pushes the fluid to do the actual squeezing of the brakes. I'm pretty sure that you shouldn't use the z32 booster or MC unless you have z32 brakes. The booster multiplies the pressure of your foot on the pedal, and the MC changes the bias of front and rear brakes (and also pressure to a certain degree).benarovi561 wrote:sorry for the noobness but bmc? i need a new brake booster and some guy offered a z32 one. and since its 20 why not. but all i know is what the brake booster is, dont have a clue what the thing that holds the liquid and all that s*** is called. sorry lol
yeah guessed correct. well thanks for the input and makes sense. but im going to have j30 brakes. and this guy wants 20 for the brake booster ill use the stock mc. or should i try and get my hands on a j30 brake booster or jsut get a stock s13 brake booster? again thanks, nico never fails.zachattack_5491 wrote:
No prob. Use the stock s13 booster.benarovi561 wrote: yeah guessed correct. well thanks for the input and makes sense. but im going to have j30 brakes. and this guy wants 20 for the brake booster ill use the stock mc. or should i try and get my hands on a j30 brake booster or jsut get a stock s13 brake booster? again thanks, nico never fails.
no, but its a noticable improvmentHuntsman2007 wrote:is there a huge benifit by going to j30 brakes?
