Won't turn over.
cjfulton259
Car: 99 QX4
First time posting here... so thanks for you help in advance.
Have a 1999 QX4 w/ 150k miles. Love the car and hopeful to get some more mileage out of her.
This week I cranked the ignition, but the engine would not start. She was admittedly low on fuel, but doubt she was empty. I finally got her turned over after three tries (waited a few minute between each try), and immediately filled her with gas.
Began to go about my errands when she stopped accelerating at about 40 mph and made some noise like a muffled backfire from the rear part of the vehicle. Wasn't really sure what to do at this point, so I pulled over and checked the spark plug connections while the engine running. All seemed secure. Hopped back in and eased her on the highway. I didn't get her above 60 mph and she didn't seem to have all her normal V6 power.
Got her home. Lucky I think.
She now is back to where I turn the key and she is cranking, but will not start at all.
At first I thought gas, then the starter when she didn't turn over, then when she nearly cut out while driving I really had no idea.
Any ideas? I'd be extremely grateful.
Thanks.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
You might need a new fuel pump and control unit if your truck has one. I am sorry I can't help you more because I have a Q45 not a QX4.
You can consult the service manual to see where the parts are located and for more help: http://Nicoclub.com/FSM
You can try this guy here to see if he has a fuel pump: http://stores.ebay.com/emgeepa...esc=1
If not try Infiniti Of Scottsdale because I only trust OEM part when it comes to doing such a job.
cjfulton259
Car: 99 QX4
Ended up being spark plug related. They swapped these out, oil changed, did some sort of system flush for 400 dollars. I wish they would have bought me dinner before they bent me over... unbelievable.
qship96
Car: 1996 Infiniti Q45
They love to push those "flushes" as they are pure quick easy money makers- really known as "wallet flushes"
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
Who did the work? Love to know so that I can avoid them. Plugs?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
cjfulton259 wrote:Ended up being spark plug related. They swapped these out, oil changed, did some sort of system flush for 400 dollars. I wish they would have bought me dinner before they bent me over... unbelievable.
Take is back if they didn't use the OEM specified NGKPFRG-11 plugs or you could lose your engine.
"Flush" and "Service" are code words that cover almost anything more than an "Inspection." May consist of nothing useful at all.
