won't turn over
mannyszx
Car: 1990 nissan 300zx 2seater 5spd
Bought a 1990 n\a new newer engine installed but when i go to turn on it starts and cranks like it wants to turn over but wont was wonderung was there anyway to check if fuel injectors are bad if there is anything else that could be wrong thanks
Milo (San Antonio)
Car: Project LOWFATZ (weight reduced slicktop TT)
You will need to Ohm test the injectors, if you want to check the injector.
As far as other possibilities, here are a few things.
1) Run a ECU diagnostic and check your codes.2) Check to make sure your fuel pump is kicking on.3) Check connections on PTU 4) Check all 6 plugs to make sure they aren't fouled.5) Check starter relay (swap out for a known working one)6) Gas in the car? Sorry have to ask.
Questions I have for you, as the devil is in the details.
Have you done any work on the car lately? maintenance/modding?Is this sudden or has this been slowly leading up to this?
mannyszx
thanks for the reply first im goona check everything you said it does have gas no mods done at all as soon as the engine was finished being dropped in this is whats been happening
