Won't start
Crautz240
Car: 92 240sx Hatch
My car is a 92 240... The other day when i went to start it the car wouldn't do anything. I would turn the key and it would click thats it. So i thought my starter was bad. I brought it in to autozone to have it tested and it passed. So i figured it might be my starter relay but when i went to look at it this is what i found Is the second space supposed to be plugged in?? and wtf is this... pretty sure it isnt supposed to be like this If relay is clicking that doesnt automatically mean its still good does it??and i looked at the fsm but it does nothing but confuse me lol
MastaYu
Car: 92 Nissan 240SX SE HB
You should try the 240sx section
Crautz240
Car: 92 240sx Hatch
MastaYu wrote:You should try the 240sx section
???? anyone??
livinglegend2100
or 240 tech section. you probably wont get many useful replies in gen chat
Crautz240
Car: 92 240sx Hatch
My car is a 92 240... The other day when i went to start it the car wouldn't do anything. I would turn the key and it would click thats it. So i thought my starter was bad. I brought it in to autozone to have it tested and it passed. So i figured it might be my starter relay but when i went to look at it this is what i foundIs the second space supposed to be plugged in??and wtf is this... pretty sure it isnt supposed to be like thisIf relay is clicking that doesnt automatically mean its still good does it??and i looked at the fsm but it does nothing but confuse me lol
Chris28
Car: 92 s13 KA-T
Your car was once an automatic. The second pic is of a connector that is connected to itself so the car thinks that it is in park, allowing you to start it.
First pic i'm not too sure about. Try replacing the relay, also check all of your fuses.
Gr8plainsDrifter
Car: 1989 240sx
my terminal on the battery is loose, and when i go to start it it does that click. check that. those connections maybe your problem, make sure they are clean and tight. it was working before? looks like it bypasses the relay?
weird240
Car: 91 redtop 240fb sold. 91 240sx fb, 95 tercel(flat black beater)
this has happened to me before it ended up being my interlocking relay. i hope this will help! good luck man!!
weird240
ps last time i checked it was a dealer part
Crautz240
Car: 92 240sx Hatch
Chris28 wrote:Your car was once an automatic. The second pic is of a connector that is connected to itself so the car thinks that it is in park, allowing you to start it.
Well im curious to know if the relay is supposed to have one open spot ad which fuses should i check thats could cause this??
weird240
that is a interlocking relay for the starter. make sure u have current going in and out of it. mine went out no more than a month ago.
they r known to go bad
Crautz240
Car: 92 240sx Hatch
I know its that it is the interlocking relay but im wondering if it is supposed to have one open spot
Crautz240
Car: 92 240sx Hatch
Gr8plainsDrifter wrote:my terminal on the battery is loose, and when i go to start it it does that click. check that. those connections maybe your problem, make sure they are clean and tight. it was working before? looks like it bypasses the relay?
That was the first thing i thought it was.. but there clean and very tight. Could it be a bad battery, i didnt think a dead battery would cause symptoms like this.
weird240
yes it is suppose to have one open connection mine did as well
theother1wstolen
Car: 92 240sx Coupe SE
pull the plastic casing off of your steering column and see if the plastic part of the ignition switch is coming out of the metal case, push it in with something that wont conduct electricity and try starting while your doing that, if it starts, you know what the problem is.
Gr8plainsDrifter
Car: 1989 240sx
It
Crautz240 wrote: That was the first thing i thought it was.. but there clean and very tight. Could it be a bad battery, i didnt think a dead battery would cause symptoms like this.
i think it could be the terminal on the battery...
Crautz240
Car: 92 240sx Hatch
So i replaced the relay.. that didnt work.. then i tried a different battery but that didnt work either any other suggestions guys??
Crautz240
Car: 92 240sx Hatch
Also i didn't mention this before i have electrical power in the car like all the lights and radio.
Crautz240
Car: 92 240sx Hatch
Well i tested the starter that isnt it... i replaced the relay no good. I can push start the car and it will start up no problem every time but i cant jump start it... while i had the car running i disconnected the battery and the car didnt die so im pretty sure its not the alternator any other ideas here guys?? could a battery alone be causing this. Im getting enough of a connection that i can push start it and everything inside works (radio, windows, lights)
theother1wstolen
its prolly your ignition switch, same thing happened to me, bought a new one, and the new one was messed up, do what i said in my previous post.
Ladreik
Car: 92 240sx se Coupe
I am having the same problem as you, my relay does NOT have an open spot.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
if the battery cells are shorted and not opened yet. Did you test the battery with a load? Did it have a positive recovery voltage? Does the recharge current go away?
grecco28
Car: 1992 240sx
, check first the signal for starter solenoid is the one terminal wire, put a test light and check if when you turn switch to start possition it should be turn on...
Crautz240
Car: 92 240sx Hatch
theother1wstolen wrote:pull the plastic casing off of your steering column and see if the plastic part of the ignition switch is coming out of the metal case, push it in with something that wont conduct electricity and try starting while your doing that, if it starts, you know what the problem is.
Could you take a pic by any chance i took the plastic of the column and have no clue what your taking about
theother1wstolen
i cant take a pic but if you look at the cylinder lock the key goes in on the right side, and on the left side there is a peice with 4ish wires soldered to it. that plastic peice starts to come loose and wont make contact so if you push it in and turn the key at the same time and it starts, you need a new ignition switch (about $30)
Crautz240
Car: 92 240sx Hatch
It's brown right?? It looked a little loose i pushed it back in and turned the key while holding it in place and that didnt do anything either
theother1wstolen
i would check your start signal at the starter.
Crautz240
Car: 92 240sx Hatch
Ive clean all connections and i tried jumping starting it by connecting the cables straight to the starter. That didnt work so i know its not the battery or cables. Could it be that autozone's starter test is fubar?? I've heard of people have there starters pass when there were actually not good.
theother1wstolen
again, check the start signal wire at the starter.
Ladreik
Are you getting 12 volts at the Control circuit comming off the magnetic switch when in the start position? If you are the control circuit is good, and the next thing to check is your starter.
make sure your car is in park or nuetral with the parking brake on.
Create a jumper and apply 12 volts at the connector comming off of the solenoid, if that allows it to turn over then your control cuircuit is bad, do you have an auto or man?
If you have an auto your control cuircuit is affected by the inhibitor switch
if you have a manual the curcuit is controled by that interlock relay that you showed aboved and also the interlock switch.
