Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Aug 12, 2008 8:27 am
Did this car run with the KA 5 speed swap?
From the sounds of it, someone put the 5 speed lower harness in it, which is incompatible with the chassis harness of an auto car.
You can use the wiring diagrams for the KA lower harness as they're identical to the SR's, btw.
As for your mystery plugs, I have no clue what they could be without actually seeing them. I can't find or think of any plugs that utilize the colors in the layout you're saying they're in.
There is a 2 pin connector that has a Black/Yellow (start signal) and a White (alternator) going through it.
The speed sensor uses a Yellow/Blue and a Yellow/black, but on the auto harnesses, they go through a 4 pin plug, and the manual has it going through an 8 pin plug
Since this is an auto swap, and you're having starting issues, make sure that the park/neutral switch plug was jumped properly. It's located at the bottom of the fuse box. Sometimes, it can slide under the fuse box. It'll be two very thick wires (Black/Yellow and Black/White), and they need to be jumpered to make a swapped car start.
