capowered240 »
https://forums.nicoclub.com/capowered240-u27587.html
Mon Sep 26, 2005 3:47 pm
I wanted to know if I have fried my ecu. I did a CA18DET swap in my S13 240. I didn't know about the dropping resistor. So I got everything hooked up and ready to be started for the first time. So I cranked it over and it wouldn't start. I did that 2 more times. It still didn't start. So I just left it alone for awhile. I got home, got on the internet and found this Nico.com, the ckicked on the CA forum. I had found that someone had wrote, you can fry your ecu if you try to start your car without the dropping resistor. Is that true? also when I turn the ignition to the on position, the red and green lights come on on the ecu, but then when I try to start it, they both go off. injectors are good, all coil packs are good, I get spark, I get fuel. Wha does that sound like? Hopefully I didn't fry the ecu.
