DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Fri Jan 14, 2005 12:57 pm
i want to be as specific as possible, because i have been working at this in below zero weather for four days now. its a 92 240sx, and this one is an automatic. It was a perfectly running car, so i decided that i wanted to swap in an exhaust cam for the intake cam, and i know to rotate it back four teeth, etc. I couldnt get it to fire so i put everything back to stock. i've tried many many different ways to time the cams, and right now the cam timing appears to be spot on, to make sure i even rebuilt my other 240 with identical distributer timing and cam timing, and it fired on the first try. all mine will do is crank, the best it can do is pop, but it wont fire. i've swapped distributers, maf, plug wires. there is spark, fuel, and like i said the set up is identical to my other 240 which fired up immediately. i checked for bent valves, and all the clearance between the cam and the shims is within spec (.012). but still the compression doesnt seem the same as the other 240, and you cant hear the air blow by the rings when you pull it through the strokes by hand. i'm stumped and i need this car to work by tuesday
