KCS wrote:I bought my Rogue in the summer, and am bummed about a couple of things. First, on two separate occasions, I've had problems getting it to start. Suspect computer problem, but not sure.
A "hard starting" problem was discussed once before. It seems it was eventually isolated to the fuel pump... and I'm assuming it was the fix since the original posted never complained about it again after the diagnosis. Here's the link"
zerothread?id=423512 KCS wrote: Also, my tire pressure warning light is on, even though the tires look OK at a glance. The dealership filled them with Nitrogen (whatever!!) and swore up and down it wouldn't seep out nearly as quickly as regular air. Can't remember what the warrantee is on that tire service (3 or 6 months), but it will be a pain to take it back to the dealership where I bought it rather than the one near my work. Aarghh!!
The tire pressure is another issue. (problem associated with the Nitrogen) "if" ...you have the metal valve stem caps. Check out this thread:
zer...roded
Also... the tire pressure monitoring system isn't really a problem ... you just have to get your head around the system, how it works, and it's idiosyncrasies. Check out this thread:
zerothread?id=330539
