180fan wrote:the low idle, have you recently adjusted your iacv? if the screw is in too far, it chokes the engine out and could explain the low rpm. other thing i'd check out is pull the plug on the tps. only other thing i can think of is any wear or carbon buildup on the back of the distributor?
I didn't even know what IACV was until I looked it up so no I didn't touch it. Though I did find a technial bulletin (Reference Number NTB96-032, Dated April 17, 1996) It's a little above my head but it refers to hard to start and no start conditions and it goes into a rather involved process of using a CONSULT or tachometer and something about determining whether the IDLE needs adjustment and iginition timing light... Wow, I hope you can see from my neophyte eyes how all of this can be rather disconcerting.
Here's a video I took this morning. The audio is not great because I had to close the door due to the rain so you have to raise your audio but you can tell I have a no start condition and it just refuses to turn over. Actually, you kinda see it try to turn over for a second in the beginning the RPMS go up to 700 and then drop like a brick and the car dies. After you hear me sigh, I give it another try and keep at it as it struggles to finally turn over. This time, I intervene and rev up and it springs into 1100 RPM for warm up.
In the this next video, I decide to show you how the car can restart normally after you get her going. Again, sorry about the audio and light...bad weather day.
