evildky wrote:Hot start problems usually are the CHTS, fuel temp sensor or O2, all should present a code, have you checked for codes?
Is the fuel temp sensor is on the front of the engine, on the level with the plenum, on the side of the vacuum actuated, well looks like a pressure regulator, yellow wire? It was missing it's plug so I temporarily soldered it to the spade on the sensor.
During testing today I was letting it idle to operating temp and it started running rough, died and refused to restart. I am going to try a can of Heet water extractor since she sat for almost 2 years before I got her running and home. While running rough, I was able to get in the car and keep it running until I tried to let it idle, then she died.
I'll report the results of the fuel additive and try to pull the codes. I am a disabled Veteran and have a tough time doing stuff under the dash. Fixing the brake lights and cruise control laid me up for 2 days. I have the climate control fan to fix too, so when I can get to where I can work in the foot well, I'll pull the codes first.
