Code: Select all
Hello, I was poking around the cables for the Ignition Control Module while the car was running and after touching them the car shot off; I cranked it and it started again; I did the same thing couple of times and the same thing happened each time so I figure that the connector needed maintenance and I proceeded to disconnect the harness to clean it from rust and dirt.
when I went to start the car I discover that I had forgotten two fundamentals. to disconnect the negative battery terminal and to take the key off the ignition.
Now My car Wont start. It cranks and all but wont start. I tested the Ignition Control Module itself in another Z32 and it works, so that is not it.
I think I can hear the gas pump working so that might not be it. I also checked the 2 places I know for fuses and all are OK.
I don't know what to do.
what can it be?
is it a fuse? how many more places for fuses are there? (inside the cabin by removing the slighting door fuse box and under the hood driver side next to a bunch of relays.)
is it something else?
Thanks a lot guys, any help will be gold
the Ignition Control Module is mounted on the front passenger side of the engine. and it has 2 connections. and it looks something like this
*** Never mind I got it; I tried it out the next day and started up... The piston was probably floated with gasoline; or the alarm was kicking in. don't know but it works now
