loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Dec 03, 2009 7:56 pm
Yes, that EVAP leak can fill the cylinder with fuel vapors and cause starting and stalling issues.
I know the fuel supply line is probably good but there is no harm in checking the actual fuel pressure delivery from the pump and filter. You need to connect a Fuel Pressure Gauge between the fuel filter and the fuel rail. With Ignition ON, engine OFF, the fuel pump should run for @ 5 secs and deliver @ 43PSI (34 PSI if engine is running). Note that the pump will automatically shutdown after 5 secs unless you start the car. You can also do a leak down test - when the pump is turned off, the fuel pressure should remain steady for at least 10 seconds then gradually go down. In my case, it took several minutes for the pressure to drop by 10 PSI. If the pressure drops immediately, you may have a problem with the Fuel Pressure Regulator or the check valve in the Fuel Pump (not so sure about the check valve).
The ground points I'm referring to are the main engine harness ground wires which are bolted on top of the engine, adjacent to the intake plenum, near cylinder #2. I've had starting problem before (no CEL nor fault codes) on our 99 I30 (similar to 4th Gen Max). I took voltage measurements, cleaned the air intake (MAF sensor and throttle valve), did fuel pressure measurement and leak down test, did plug 'spark' test, listened for injector 'clicking,' checked vacuum and other components but still car won't start consistently. I pulled out the ground wires, cleaned the lugs and grounding points, re-installed and then applied dielectric grease (to prevent corrosion). The car never have had starting problem since then (3 years ago).
